baltimorebiker
A bestech bms suchs as this one:
http://www.bestechpower.com/444v12spcmbmspcbforli-ionli-polymerbatterypack/PCB-D105.html
or one of ebay like this:
http://www.ebay.com/itm/44V-48V-50-4V-12S-60A-Lithium-ion-Li-ion-LiPo-Li-Polymer-Battery-BMS-PCB-System-/221644780045?ssPageName=ADME:X:RTQ:US:1123
They both state to charge at 50.4V but these chargers are hard to come by and expensive. Its easy to find 55V or 58V chargers. Can I use a 55V or 58V charger on the BMS? Shouldn't the BMS protect from over voltage? Is heat dissipation the issue or something like that?
As a side note, I'm going to run 12 nissan leaf lipos with one of those BMS I linked above. Thanks.
If the BMS won't accept 55V or 58V, I would rather use a 12s balance charger and go without a bms. And use this charger.
http://www.hobbypartz.com/75p-1220-charger.html
