scootergrisen said:Volt * Ah = Wh.
So i guess you are using a 12 volt system.
That 48V is just a "nominal" ballpark. At 100% Full charge may measure 55+V, when nearing "empty" under heavy load may drop to below 40V, with lots of ups and downs in between.scootergrisen said:My battery is 48 volt 25 Ah so its 1200 Wh.
48 * 25 = 1200.
john61ct said:That 48V is just a "nominal" ballpark. At 100% Full charge may measure 55+V, when nearing "empty" under heavy load may drop to below 40V, with lots of ups and downs in between.scootergrisen said:My battery is 48 volt 25 Ah so its 1200 Wh.
48 * 25 = 1200.
The specific numbers will also vary depending on cell chemistry.
That 25Ah is likely to be a marketing exaggeration, and even with accurate measuring tools, the actual capacity will vary by **a lot** depending on discharge current rates, temperature and the cells' SoH.
Measuring in Wh those variations will be **much** greater, which is why sticking with Ah is a good idea.
john61ct said:As I said, Wh is indeed useful when comparing systems at different nominal voltages.
Just measure at Ah with your meter, and multiply times the average (or nominal) voltage to get Wh.
What type of pack are you monitoring, cells used, chemistry, how many in series? A link would be ideal. Also to the meter.
john61ct said:Well they can be, for instantaneous Amps vs Watts, based on what the voltage is at that instant.
If I were designing a coulomb-counting meter I'd track both separately internally, then display either or both Ah/ Wh as the user selects, perhaps with an "average voltage" over the tracking period so it makes sense.
