Can I replace my BBS02 motor core / rotor with a BBSHD?
mickyd said:
tomjasz said:
CrustyToez001 said:
It works!
Bull.
Doubting 'tom' huh? :lol: That's good. Calling out questionable information in forums is important. We'll see if any proof gets shared with us.
It can’t be proven.
The poster was last seen, “Last active:Oct 21 2022 10:12pm”, yet nothing…
I'm running a BBS02B with BBSHD controller, can confirm that picture is correct, it fits and you need to change the bullet motor fase connectors can you
Can you run the controller at 25A without worrying about your controller and motor over heating quickly? and is it stable running at 1300w?
And is there a video tutorial on how to change the bullet more fase connector?
Yes it's stable at 25A, that's the same current as bbs02 stock controller.
I run mine at 52V 30A, as long as I don't push the throttle for too long it doesn't overheat, I use it mostly with pedal assist.
As for the fase connectors I bought the correct connectors and a crimping tool from a local electronics store, didn't search for any video.
