Chalo said:
It's easy and cheap, because of those crappy chopper bicycles from the early 2000s I was talking about.
https://www.niagaracycle.com/categories/weinmann-alloy-rim-20-x-4-1-4-36h-black
And "cheap" is probably what you'll get, because,... "You get what you pay for!"
Since I too am currently designing and constructing a new build that specifically requires a good quality 20" "fat bike" rim, I too have had the same difficulty! AND, the difficulty is made even greater by the rather unclear and/or deceptive (intentional or not!) practices of manufactures, distributors, dealers and sellers! Buyer BEWARE! Yes,... you can easily get "cheap" and "crappy chopper bicycle" rims (most notably, Schwinn OCC Chopper), and I've seen SOME cheap single-wall steel and alloy rims. But what of us who REALLY, want a good double-wall alloy rim, like anyone else!
I'm sure the site noted here is very reputable, but this particular item (linked above) lacks the important info and specs. that I need to know! It does NOT specifically state that it's double-wall, or that it's Weinmann's DHL-101 or any other specific Weinmann description. It states "4-1/4 inch",.... HA! Is that max Tire fitted? or actual rim width??? The Weinmann site specs the DLH-101 as " 20x3.0-4.1/4 " and accompanying cross-section dimensions overall width of the double-wall rim at " 100 ", (I HATE the mix of SAE and Metric, especially without denoting inch or mm!!! And I won't touch the issues of SAE vs Metric in this topic,... ARGH!!!) The illustration in the link above, does not have a Weinmann label as others on their site do, but I could find no matching illustration on the Weinmann site. Strange that I see listings for 26" DLH-101 that are more than TWICE the cost of that 20" Weinmann rim, so I'm left wondering if this is jus a "cheap and crappy" single-wall rim. The apparent drilled hole spacing and location is also important to me when considering a hub-motor.
Hillhater said:
From the... "best bang for the buck". thread above..
http://www.leafbike.com/products/diy-bike-conversion-kit/20-inch-electric-hub-motor-kit/20-inch-48v-2000w-rear-hub-motor-beach-snow-fat-tire-bike-conversion-kit-1086.html
I noted this on the thread above, as my choice of purchase,.... they spec the rim as "Rim: 20 × 3" double wall Alloy ( Fir for 20 × 4.00" tire )", Fir??? LoL!!!. Not exactly what I want,.... as I truly desire a 100mm or 4" overall width. I didn't find that Leafbike has yet made this particular hub-motor available separately, as I would indeed lace it to a desirable rim myself! Although this kit will limit me to the "minimum spec" of my design, a max tire size of 130/90-16,... I will still build to my desired rim and tubeless 160/80-16 tire, with hopes I'll eventually FIND available that good desirable rim.
Soooooo,.... WHERE can one REALLY get a good 20" double-wall 100mm rim??? or a 20" Weinmann DLH-101 rim?? Can you order from Weinmann direct??? And what of that rim listed? IS it a double-wall rim???
Other notes-
It was jus over a year ago that last ordered from Leafbike. Don't remember exactly how long it took, but I DO remember being VERY surprised at how quickly I had received my order.
And YES,.... a 160/80-16 tire IS about 6 1/2inches wide and also 26" in diameter. Note the motor above has an "install: spacing of 170mm or more", with "Freewheel / Cassette: space for 6 or 7 gears". I'm ALSO designing for a single speed and MAY need to be a little "creative" to accommodate chain-line.
