ProDigit said:
Any better solution than this? I can't simply plug in a battery in parallel with the main battery, especially if it's a different type, now can I?
Do these battery packs have a BMS?
Is the fully-charged voltage the same on both packs?
Is the fully-discharged voltage the same on both packs?
If the answers are No, Yes, and Yes, then there really isn't a need for diodes. The main reasons they are needed:
--if the BMS of a pack has a problem with voltage being fed back into it thru it's discharge wire, because of a paralleled pack that is ever in a higher voltage state than it is.
--If one of the packs is a lower voltage than the other, and both are already at full charge. The higher voltage pack could then further charge the already-full lower voltage pack. In some chemistries, this could be a problem of one type or another; in others it just results in wasted power and heat.
--If one of the packs is a lower voltage than the other, and both are already at full discharge. The lower voltage pack coudl then further discharge the already-empty higher voltage pack, potentially causing damage of one type or another to it.
Otherwise the only thing a diode does (besides drop usable voltage at the controller and waste some power as heat) is to prevent the potential small waste of power due to charging inefficiencies, as a pack that discharges faster is recharged by one that discharges slower, assuming that this even happens in reality (vs theory).
True, the gate needs a lower voltage than the main input, but one can either use a resistor to lower the voltage over the gate, or use a high power triode, (say one meant for 110/220V) that will allow 48V over the gate.
Now I would not use bulb-style triodes like on wikipedia. They're surpassed by solid state ones, that are far more efficient!
I suppose there might be one around someplace, but I'm not aware of any actual solid state triode. You can make a FET *behave* like a triode, by doing something like this:
http://www.radiomuseum.org/forum/the_trioderizer_a_solid_state_triode.html
but a triode isn't the same as a FET or transistor. Effectively they can do very similar things, so I can see why you are using that term--but if you use a term that is intended for a functionally-different kind of electronics when talking about "modern" electronics, it's not going to help get your point across to most people.
I also don't know off the top of my head any common FETs that could handle 48V at the gate. Most are maybe 15V max.
At this point, the guy making these 'ideal diodes' does not have them available yet.
I believe Tiberius here on ES used to make some, and there is a schematic in the thread that you could use to build your own.
