eSurfer
That is really funny. I'm amazed those prankster guys didn't get punched...some of those dudes were really mad.
Which is why that's what is on CrazyBike2--a pair from a 1985 Ford LTD.Chalo said:I think a horn is only worth having if it sounds like a motor vehicle horn. The offender's instantaneous reaction should be, "oh crap", not "what is that?"
macribs said:Decided on and installed a horn. Here's my setup: https://youtu.be/when3v7NVFk Do you think I overdid it?
More like this: https://youtu.be/zC4G9s7GO4o?t=68
Wheazel said:Account for that they dont see you.
tiny_n_terrible said:Most drivers here are elderly.
They look at you and then pull right in front of you.
When I rode an ice powered motorized bicycle I used a 35 watt driving light powered by a discarded Wallmart electric bicycle lead acid battery 12 volt 20 amp hour.
With an un-muffled 48 cc two stroke They can hear you coming a block away. All the Harley Davidson motorcycle riders use open pipes for survival.
I am now using two 20 watt led driving lights, and two 105 db horns powered off the 60 volt pack.
The electric car owners complain also. Not enough noise . The little old ladies pull in front of them too.
Ride before or after rush hour.
For me the safest time to ride is after 9:00 to 11:00 Too hot in the afternoon summer. Or in the summer when the Snowbirds are gone.
All the locals shop at night. The drunks get up at noon.
John in CR said:The side of the road is the worst place in terms of visibility, and to me riding slow at the side, trusting every passing driver to avoid you, is absolutely insane.
I must be in SERIOUS trouble. :lol:The fingers said:“Bicycle products should be installed and serviced by a professional mechanic. Never modify your bicycle or accessories.”
tomzgreat said:The AirsoundZ Air horn definitely helps.
It is so loud and startling. I've had drivers in front who were going to pull out stop in there tracks.
I also use a Strobe light and a Rear Helmet light during the day.
Be seen.!
eSurfer said:tomzgreat said:The AirsoundZ Air horn definitely helps.
Be seen.!
How many blasts is the Airzound 2 good for without pumping up? That's my only concern.
Could you guys fill me in on the 12V converter process? Where to buy? How to rig? What kind of horn should I get? Thanks.ebent said:Tomz, It looks like you will need aa and aaa batteries for the lights. More maintenance and expense. You already have the power on board to power your lights and a horn. If I had a non electric ride I would have an airzound. But with power no need to repump and replace batteries. Set it and forget it! Get a 12v converter!
