Caster is normally the term used with car wheels. I think for bikes you call it steering head angle (rake) and trail. Trail is the distance from a projected line through the steering head to the ground and the tire contact point. You want the tire contact patch to be slightly behind the steering axis to give you the caster effect.
Increasing the trail makes the wheel straighten out by itself more and increases stability. Too much trail and the low speed handling will be adversely affected. Too little trail and the steering becomes unstable and prone to wheel wobble. I'm not sure what "optimum" is, but there is a lot of research that has been done on the topic. There is a trade-off betewen high speed stability and low speed manuverability.
On my Vegos, the trail was actually negative, which is totally unstable. This makes riding with one hand nearly impossible. I reversed the fork crown to increase the trail, which helped the handling immensely.
Thanks fechter
i have 65 degrees
trail ~3.5"
16.5" tire
no rake
now i need a base to compare it to.
Nothing in those articles gave any idea what is popular and at what speeds it works well.
My miyata has a much straighter front end, while the oryx is layed back. The miyata's fork is curved at the end, and this makes for pretty good suspension. Oryx feels good at high speed, Miyata feels good at day-long speeds Guess it depends what you want.
