Cha-Ching !!!
OK, I'm assuming from the title and the variety these are warranty return packs you scored from a service center, right?
Regardless of the source I would recommend using a screwdriver for dismantling rather than putting them on simmer or boil. :p
That's correct !
On my lunch break today i got my cell phone and started with the yellow paged, made a few calls and found a service centre that was very friendly !
Dropped in for a visit and talked with the guy, explained that i'm not a " Total " idiot and understood very well what i was asking for. Went in the back and he had a bucket of power tool packs, nimh, nicad, and low and behold LITHIUM !
I gave the good man 20 $ and said " Thank You ! " and i'll be back once in a while to check in ! :wink:
Damn it feels good to get something cheap once in a while.. 8)
Opened one of the Makita 18 v packs, 5 green 18650's, 4 showing 2.7v and one 0.9v ..
Going to read up on Dr Bass threads right now !!!!!
Black and decker on amazon. 1.1 amp hours
you can buy with charger or seperate batteries and dual chargers
battts are 1.1 amp hours.
B&D are unable to provide the C dicharge rate
Are these any good?
http://www.amazon.com/Black-Decker-VPX0511X-Battery-Charger/dp/B000UMLDX6/ref=combo_pack_i_9/002-6096683-6022417
http://www.amazon.com/Black-Decker-VPX0320-Dual-Charger/dp/B000UMJJFA/ref=combo_pack_i_7/002-6096683-6022417
http://www.amazon.com/Black-Decker-VPX0111-7-Volt-Battery/dp/B000UME3JC/ref=combo_pack_i_2/002-6096683-6022417?ie=UTF8&m=ATVPDKIKX0DER
Ypedal dont you know that to leave some li-ion battery on a oven top can become very dangerous :p !!
The makita li-ion battery have all the same problem. One of the cell is dead and the next in serie are right. the service center guys said that and i can confirm too... 98% of thepack i've dissassembled and measured had that trouble.
Fanciest way would be to turn the cooker top on Y :lol:
I followed these instructions to get 60 cells from twelve 28v packs
http://www.swift-tuning.com/emoli.pdf
Found the SMC battery bars at
http://www.southeastrc.com/Items/StdItemView.aspx?lookup=SUMIB28S
Now I'm looking for a BMS...
BatterySpace has PCM for 10 cells
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=3558
or 7 cells
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=3247
