Hello everybody. Huge headache here, just transferred my bbs02 to a new bike and the chain line is awful and my 32T aluminium chain ring is eaten up after just a few days. Running a 1x11 setup. I have an idea for a pulley wheel thing I saw someone posted on here somewhere, to correct the chain line, but will require some things I'd have to order, and not sure it'll be sufficient. Does anyone have experience with the stainless steel chain rings that are available online? Do they wear much less so that a crappy chain line is not as big of a problem?
Example chain ring here http://www.wolftoothcomponents.com/products/104-bcd-stainless-steel-chainrings
Even if this S/S chain ring wore ten times slower, at this rate I'm at now with the aluminium one it wouldn't be much better. Literally five days of riding, 2-3 hours a day and the teeth are shaved off like butter.. Any advice is much appreciated. I would like to not have to resort to angle grinding the bottom bracket, although I see that I could save probably 5 whole millimeter that way. Would like to be able to slap the manual cranks on if needed, should motor fail etc.
Cheers! Simon
My situation: http://imgur.com/a/4BDE2
Cheers! Simon
