Im about to buy the $1050 Roadster V2. Ive never built an e bike before but I already own a great little single speed that's only 19lbs. I want to see if the experts here would recommend I build instead? Thanks for your time.
Goal:
<33lbs
"pedal assist up to 24 mph,"
Range 20-30 miles
<$1050
Desired max speed on level ground: 20mph
Desired max range at what cruising speed: 10miles
wheel size of bike you want to convert: 700x23
Bike: reliable but older 19lb single speed, (love the bike but its not work much ~ $100) aluminum frame, drop bars
Fitness level: Can pedal 10miles, but would rather not after a long day at work.
Skill level: competent bike mechanic, no electric motor experience,.
Weather: PNW, wet often
Brake type of motor wheel.
Brakes: Caliper
Rider weight: 145lbs
Terrain: mostly flat, some short hills under 20% grade.
Budget: ideally under $500 up to $1000 if needed
*keeping weight low to carry up stairs.
would this kit work? https://www.amazon.com/EBIKELING-1200W-Direct-Electric-Battery/dp/B09LBTCFD9/ref=sr_1_3?crid=39PGCFTJPP5W0&keywords=Ebikeling%2B700c%2Bwith%2Bbattery&qid=1648687635&refinements=p_36%3A-84000&rnid=386589011&s=sporting-goods&sprefix=ebikeling%2B700c%2Bwith%2Bbattery%2Csporting%2C133&sr=1-3&th=1&psc=1
Goal:
<33lbs
Range 20-30 miles
<$1050
Brakes: Caliper
