According to this rough simulation
Our ebike motor simulator allows you to easily simulate the different performance characteristics of different ebike setups - with a wide selection of hub motors modeled, and the ability to add custom batteries and controllers and set a wide variety of vehicle parameters you'll be able to see...
ebikes.ca
you can go about 25mph with under 800w of motor power, which is just under 1000w of battery power (efficiency losses in system), with around 36wh/mile capacity usage.
That assumes the default riding position and motor and wheel sizes in the simulator, and using the max weight already listed in the dropdown; not knowing your riding position or wheel size or motor type or scooter weight I couldn't put those in, but you can use the link above and modify the simulation to better match your actual stuff for a more accurate simulation.
At a 15% grade it wont' even move according to the simulation.
ebikes.ca
upping it to a 60v system at 30A it still won;t move on 15% grade
ebikes.ca
Going to 100A it'll go 16mph up 15%
ebikes.ca
but it's taking about 4kw to do it and almost 240wh/mile so your motor would overheat in a couple of minutes or less, and your battery, assuming 60v 20Ah (1200wh) would last about 5 miles of that kind of hill climbing.
So...if it takes about 4kw to go 16mph then if that's fast enough for you you can change your motor wheel out to something big enough to handle 4kw minimum from QSmotors (if they have one that will fit in your wheel size and dropouts, whatever those are).
Then change the controller to something that can handle at least 100A.
Then change the battery to something that can supply at least 100A, and has enough capacity to get you as far as you need to go.
