Ypedal
100 TW
After posting that picture, i realized my tape job sucked...
I had to remove it and redo it with paralell lines... i'm such a prick somedays.. Don't they have pills for this behavior ?
Ypedal said:After posting that picture, i realized my tape job sucked...I had to remove it and redo it with paralell lines... i'm such a prick somedays.. Don't they have pills for this behavior ?
rxlist.com said:Lithium carbonate is indicated in the treatment of manic episodes of manic-depressive illness. Maintenance therapy prevents or diminishes the intensity of subsequent episodes in those manic-depressive patients with a history of mania.
Typical symptoms of mania include pressure of speech, motor hyperactivity, reduced need for sleep, flight of ideas, grandiosity, elation, p.o. judgment, aggressiveness, and possibly hostility. When given to a patient experiencing a manic episode, lithium carbonate may produce a normalization of symptomatology within 1 to 3 weeks.
xyster said:Wow, nice work!
What sexy packs you have, you must work out!
Would your batteries like to meet me sometime for a little pick-me-up? Maybe a little hot lithium-on-manganese action?
Lowell said:xyster said:Wow, nice work!
Is that with or without duct tape?
Ypedal said:Hehe.. you can cold form 1/8" stuff.. but FORGET bending 3/8 unless you took your morning steroids... if you had access to a very large industrial press break. mabe.. but i don't got that.
Ypedal said:1/8" should be fine for fairing, i have both on hand, and used the thick stuff for the packs as the glue edge was wider and the packs are heavy...
fechter said:Are you going to give them some ventilation?
I'd be worried about the strength of the corner joints where the halves of the box are glued. On the other hand, I've never tried polycarb solvent glue.
If they come apart, you could reinforce the edges with some aluminum angle. You could drill and tap into the plastic and use a bunch of short screws (or sheet metal screws).
Ypedal said:I just got a call from my neighbor, he got his hands on the real deal adhesive for the polycarb.. i'm told with the special stuff it WILL NOT come apart.. ever... lol..
Bigh - What was the picture's source ? those look cool !
Venting.. i considered this, the Li packs do not get hot during use ( so far ) and i considereed the Venting vs Weatherproof situation..
To vent or not to vent.. that is the question.. :?
