I apologize in advance if the answer to this question is obvious, or if it has already been discussed, or if I'm being thick, but I'd really like to understand this fully before going ahead with my project.
Okay so the question is this: can you charge a LiFePo4 battery pack while at the same time using the motor? Or in other words, will the charger be totally confused because of the voltage drops due to the use of the motor?
The reason I'm asking is because my electric bike is now fully functional, and I'm now ready to move on to the next stage of my project - which is build a trailer with a solar panel to power the bike / charge the battery on the road during my tour next summer.
I'm planning on getting a reasonably small solar panel of some kind (100-150W, not sure what kind yet), connect it to a Genasun lithium solar charge controller, and connect this controller to the battery. I believe it should charge the battery fine when the bike is not moving (provided there's enough sun of course
). But what I'm concerned about is this: if I ride and use the motor at the same time, there will be a significant voltage drop seen by the Genasun controlelr (not to mention a lot of induction noise). When I stop using the motor, the voltage should go back up. Won't that confuse the hell out of the controller?
My understanding is that lithium battery chargers are supposed to follow a CC/CV charge profile (or at least CC to get the battery pack charged to 95% of its capacity). So I suppose they constantly watch the battery's voltage, and switch from CC to CV above a certain voltage. I wonder if wild voltage variations due to the load of the motor will throw the charger "off track" so to speak, and cause it to damage the battery.
My intuition is that it should work though. I've googled quite a bit on the subject, and found of couple of pages made by people with electric bikes and solar panels who mention they use a Genasun controller and a LiFePo4 battery. So apparently there's nothing more complicated to it than connecting everything to make this work, as these people didn't seem to make a big deal out of it. Also, if the controller is indeed a CC source (at least for part of its charging cycle), it stands to reason that if the motor is pulling amps, the controller will simply supply part or all of the current it supplies to the motor instead of the battery.
Of course, there's a simple way of testing if this works: I have a 28V 8A wall charger with a bargraph display. I could just throw the bike on rollers with the battery fully charged, connect the charger, and use the motor. If I'm correct, the charger's display should drop and show it's "charging" when I use the motor, and go back up and stop charging when I let go of the throttle. But before I try it, do you think I risk damage to either the charger or the battery doing that?
