Mike_Kelly
Established
If I have a lion battery pack that has a built in BMS. The BMS module is managing the charge cycle and equalization of the cells.
My problem is that I bought a Renogy Boost Rover solar charge controller because it can charge "lithium" batteries.
I was not thinking when I got it that the boost controller will have no control over the charging, the BMS in t he pack will.
So then I find that the Renogy Boost Rover, in the manual, talks only about charging LIFEPO batteries, which I know nothing about.
So the bottom line is since I really don't want the solar boost controller to do anything but boost the voltage and then be a constant power source for the BMS what setting on the range of chemistry options on the solar charger will do nothing but boost and supply power vs a say lead acid setting that has multi cycle charging secenario which I don't want or need? AGM/Sealed, Gel, Flooded, and Lithium?
