Hi guys
I bought a used 10s pack, pretty sure chinese cells, that I opened to check the type of cells in the first place. Didnt see any markings though.
Anyway on the very small bms that it has, i can see the thin positive and negative charge wires soldered on the bms near the thicker main wires. The original outer casing has 2 different connectors. One for charging and the other for main power.
Is it possible to just remove/ignore the thin charge wires and then charge the pack directly through the main power plug?
Thanks
Thanks
