flangefrog
You mentioned you had some Sanyos at the end, what model are those? Also the LG Orange cells, from what I can find they're 2100mAh similar to the UR18650RX?
These Sanyo are UR18650SA (1300mAh, 10A dc). In 15 cells packs but glued to plastic case. I will give them for FREE for first few orders.flangefrog said:You mentioned you had some Sanyos at the end, what model are those? Also the LG Orange cells, from what I can find they're 2100mAh similar to the UR18650RX?
tumich said:These Sanyo are UR18650SA (1300mAh, 10A dc). In 15 cells packs but glued to plastic case. I will give them for FREE for first few orders.flangefrog said:You mentioned you had some Sanyos at the end, what model are those? Also the LG Orange cells, from what I can find they're 2100mAh similar to the UR18650RX?
These Orange LG have about 2100mAh but don't know about max discharge rate.
The batteries brand: LG
Batteries code: 18650 MG1
Nominal capacity: 2100 MAH
Batteries color: orange
Batteries specification: 65 * 18.4 mm
Batteries resistance: 20 milliohm below
Batteries voltage: 3.75 V
Test current: 0.3C
Charge cut-off voltage: 4.2 V
Discharge cut-off voltage: 2.75V
Maximum discharge current: 10A
Pretty sure tumich doesn't have LG HG2. Closest is Sony VTC5 (less capacity, heigher discharge rate) or Sanyo NCR18650GA (more capacity, lower discharge rate) If you do need HG2 you can get some at http://lunacycle.com/ if you're in the US.chinyp said:Hi, I'm looking for a dozen of lg hg2 brown batteries.... Any way to get it and soldered in flat 6s2p? I mean can you get this? You sure do have a way rite...hehe Please do quote me the price of each. Thx
Highfreak said:Tumich, my cells arrived today in great shape, balanced voltages and best of all no surprises! Thank you for the EXELENT service.
Dave
DAND214 said:So does this mean, you only sell loose cells now? No more welded packs.
Dan
markz said:Thats all thats on the shelf at "The Tumich Store"
I'm sure there will be other stuff sooner or later, perhaps a candy you'd enjoy, maybe an ice cold Cherry Coca Cola and some Reese's Pieces Bits.
tumich said:All cells usually aren't older than 1-6 months from fabric.
Honk said:Hi tumich.
What is the production date code of the Samsung 29E.
By that I'm asking how old is these cells.
