Madmarcus
New-ish here
I'm interested in some 30.6V (8s) 67Ah batteries for use in different electric vehicles. I like the 67Ah but for at least one application I might prefer a series connection to give 61.2V. I have two thoughts on a BMS and I'd like to hear opinions of each.
1. Wire each battery with an 8s BMS.
This would allow me to separate the batteries when I didn't need 60V (and potentially for charging) but how do I use the two different BMSs while using/discharging the batteries?
2. Wire one 16s BMS.
Potentially annoying from a wiring and soldering aspect because the wires might need to be lengthened but that's not a big deal. Is there any drawback that I'm not seeing? Would I have to put on individual 8s BMSs first, charge them separately to the same point, and then take off the 8s and replace with the combined 16s or can I do the initial charging safely through the 16s BMS even though I don't know the initial state of the cells in the two packs?
Finally would the answers change if I had two battery packs (different batteries not the ones linked above) that I wanted to connect in parallel? It feels like series connection would be best with one BMS but parallel might be better with separate BMSs.
As a general note I do not want to get into breaking the battery packs into individual cells and rebuilding them.
