Thud
Paralell all the way. I double the controllers & trust that the sum of the 2 will be more than required for durability.
As for parrallel motor set up with a single controller. it is simple in theroy. you need to mechanicly "lock" the outrunners spinning parts together so they keep in perfect time with one another. Then have sensors in one of them & a controller that will pump the current they'l accept.
To series a 3 phase motor,you would need to have all the starts & ends come out of one motor(call it the slave motor) & series the phases into the 2nd motor with the delta or wye termination in that one. (sensors could be in either)
You would need to identify each phase of the motors & keep all the wiring straight. Fechter recomended setting the motor positions by energising a single phase & letting it position the rotors then tightening down whatever your using to keep the sync (belts/chains)
sounds simple eh? LOL!
(hmnn, got me thinking now. Parrallel or series, a single timing adjuster would be in play on that set up..less space taken on the bike, lighter & gives me more spare parts to change out after i put out the fire. :wink: )
Thanks, I think i just found justification for 24fet controller! (this hobby is killing my check book!)
