Wonder why louder. Maybe the rear sprocket pitch doesn’t match the chain
Getting all ur battery weight in or under the frame triangle would be ideal.
I’m printing a box right now that bolts onto the frame tube and holds the battery. I’m finding 3d printers are available at a lot of libraries these days. If they have a bed big enough is an issue though. If u pay for filament I’d print it for u and I got a 350x350 bed.
I dont know your controller but if u get a vesc regen is easy to set up u need a two-way throttle or something
That's really nice of you, I might have to take you up on it. Right now all the cells are inside individual "scooter" packs that are hard plastic cased. And I've got 3 packs in each orange box. They are about 13"x4x3 each. You think Id need take them out of their hard cases to save space?
The Marin city and Tiburon library both have Makers Spaces with printers and also laser cutters. There’s also Noisebridge in the mission with lots of different kinds of tools n printers
These are pla filament below and maybe like $7 each in material. They’re just testers for fit and then will try to print polycarbonate with carbon in it. Or on YouTube I see it’s not worth trying to print these high temp finicky materials and instead just add carbon or something with epoxy. I might do a layer inside of NOT carbon as it’s conductive but Kevlar (good safety feature)
I dont know about ur battery and what would fit. I imagine ideal would be one case that clamps on ur down tube. If u design it I’ll print it. Yea you’d probably want to open the packs u have and reorient and likely reweld or maybe use copper n magnets. There’s some great deals on lifepo4 cells (gotion) someone on the forum is selling a buck each n he lives like an hour and a half north. Safe chemistry and big cells to make assembly easy.
I know u already have an esc but with a vesc it’ll be easy to adjust things and fit on the side of the box easier. The other holes are a charge port “dc jack” and loopkey with qs8 anti spark plug to turn on and off. Will be waterproof
Only time I really hear chain noise on a reasonably sized sprocket is when something / anything is slightly out of alignment. If you have one the of many that just will not stay 100% true thicker lube will help quieten the noise.
Alignment could be the issue.
or
New large sprocket doesn't appear to have side taper on the teeth nor do the teeth look to be de-burred.
(compare tooth profile between motor and new big)
I've made sprockets with laser and waterjet and then tapered the teeth by hand with a sander.
