gtadmin
[sternvoice] Is this part of the CB80 implementation plan? If not, stop pissing around and get on with the important stuff [/sternvoice]adrian_sm said:Update: Brain Box
Here is the update on my throttle interface, or as I like to call it the Brain Box. It is based on Arduino so I can get hardware off the shelf, and speed up development. Later on who knows.
So finally got the bits on Friday, only had a couple of hours to play with them yet, but managed to get the following working:
- wheel sensor (using an interrupt)
- button throttle input (digital)
- battery current sensor (analog)
- battery voltage sensor (analog)
- basic PWM out for the throttle out to ESC (PWM)
This gives me most of the building blocks I need. Now I "just" have to get all the logic working. So far I am really happy with it. It looks like it will be able to do everything I want, and has been really quick and easy to get things working.
- Adrian
Top stuff Adrian, it's getting closer. Are there going to be (user) adjustable set points, or will it have presets for the different motor sizes, or doesn't it matter? If the wheel sensor was to work off the chainrings (ie no pedal, no assist), it'll almost be legal , or do you want an absolute speed reading before assist?
Cheers,
GT
