markz
100 TW
Number Dont Match Up
HCX-D131 website states http://www.bestechpower.com/74v20spcmbmspcbforli-ionli-polymerbatterypack/PCM-D131.html
80A max charging - 80A max discharging - 84V
emailed pdf file states 20S-50A max charging and 50A max discharging 84V Charging Voltage
Couple Questions.....
Cant charge at 80A or 50A anyway. But discharging rate difference 50A and 80A?
So even though its 84V it drops down to 74V taken off charger?
Do I even care about discharging amperage when buying a BMS?
Does the BMS control voltage to controller when I am riding, meaning is the BMS hooked up to the controller when riding?
And hooked up to the charger when charging?
or is the BMS only used in the charging, hence dont matter if its 50A or 80A charging rate?
