If you're really insistent on using this specific motor, then, in order of ease of doing so, you'll either have to:
use a sensorless controller
or
add sensors to use it with a sensored controller
or
figure out how to design and add electronics to the sensored controller to read motor position information from the phase wires.
The first is very easy, but costs more money than the second.
The second is cheap, a few dollars for hall sensors plus some hours of your time, but not quite as easy.
The third probably costs more than either of the others, as you'll need some test equipment, parts, and a lot more time researching how to do this (and probably learning a lot of electronics along the way). The only advice I can offer on how to implement it relatively easily is to buy one of the "fake sensorless" controllers that already has the little board inside to convert phase to hall info, trace out the circuits, buy all the necessary parts, and then build your own, and put that in the controller you want to use, if you don't want to use a different controller for reasons other than cost. But I don't know any way to tell if a controller already has this board in it other than to open it up, as they are just listed as sensorless controllers, just like all the other sensorless controllers that get motor position information some other way.
And it's much much easier, and probably a lot cheaper, just to use the new controller to run the motor without even opening it up to peek inside.
If you really don't want to put hall sensors in the motor, and dont' want to do any of the above, there's a thread by Burtie that discusses adding external optical timing sensors to the motor instead, but that's likely to be more complicated and potentially more expensive than just using a sensorless controller.
If you don't want to add any kind of sensors to the motor, and you don't want to do any of the above, then I don't know any way to make what you have work together.
