Beagle123
Hi:
I own one of these charger bicycles:
http://abc.eznettools.net/D300013/X300109/ebike1.html
I'm converting it from 24v to 36v. I'm only salvaging the motor and torque sensor. Everything should work fine except the new 36v controller uses a standard 3-wire throttle, and the torque sensor that 's attached to the chain of the bike doesn't seem compatible.
The problem is that the twist throttle puts-out a voltage of 0.4v to 3.5v when attached to a 3.9v battery. The torque sensor puts-out a voltage of 0.4v to 0.7v with the same 3.9v battery. So if I just connected the controller to the torque sensor, it would only give a slight signal to the controller. I want the torque sensor to produce the full-throttle 3.5v when pressed hard.
Is there a way to make the sensor output more voltage? Is there a way to make the controller use the lesser voltage? Do I need a custom circuit? Suggestions?
Thanks,
Eric
Thanks,
Eric
