RVD
Hi Everyone,
I have the 9 FET 72V Infineon Brushless Controller (LYEN's Edition).
As you can see in the picture, this is a picture of where the battery should plug in. You see 2 anderson connectors for the +/- from the battery.
Between them you can see the thin red wire. This thin red wire is for the ignition. I don't have an ignition wire so the documentation (and Edward Lyen) says that I should just hook this up to the positive.
However, I have a few quick questions if I do that:
1) Will this cause a spark when I hook up the batteries to the controller? There is no on/off switch on the controller.
2) What is a good way to just connect this to the positive of the battery? Should I create a Y connector out of the battery so that 1 anderson goes out to the controller red and another anderson connects to this thin wire (convert this thin wire to anderson)?
Or should I strip this wire and solder it to the controller red wire together and crimp them together to form 1 anderson and then just plug in my battery to it?
Or is there another way that I should do this?
3) Is it easy enough to create an on/off switch and use the ignition wire for it? I think I would rather have an on/off switch for the controller if it's easy to build one using this red ignition wire.
For example, maybe hook up the ignition wire to a switch and also hook the switch up to the battery using a Y cable (one battery out to ignition + power on controller) and use the switch to turn on/off the controller?
