PITMIX said:Yes I am optimistic and a 2 hour power outage doesn't scare me.I won't use a single drop of gasoline for so little
I've read of this behavior, but I've never experienced it.Is there a possibility that, if I disconnect all the wires between controller and motor, connecting only the thin power wire to the controller, that I can access it and change the setting which causes this behavior? The manual says this behavior is launched by the entry of "170" in one of the fields- if there is "85", the controller will think the "angle setting process" was successfull.
Fany got fired like a year ago.Your best bet is to contact Fany at Kelly directly
Oh-I didnt mention it because it appeared self-evident. Of course I have the chain removed. The motor has only the sprocket to its axle.I would try removing the chain to remove any load to the motor, then do the angle test again.
Happy to see you back!
Fantastic build sir, looks very clean and just awesome to save a real Bultaco. Best regards bro!I have now written an email to the Kelly customer support, describing the problem and asking them about a way to reset the controller. I hope they will reply...
Thanks to everybody for the welcome
Just in case you haven't seen it yet:
Here is a link to an YT video I made about my build, including some short riding sequences.
It is not listed on YT, so you will not find it there unless using my link.
