Hello,
I'm just starting my first ever ebike project, having become a parent lately I need some form of family transportation. Because cars are smelly and expensive I've bought a brand new cargo tricycle, like the one shown in the picture, which will be delivered the 16th of June, I intend to electrify this thing, allowing me a top speed of at least 15mph and hopefully a 40 mile range on a $3000 budget, (of which I've already spent half on the bike and accessories and still need a couple of things like a heavy chain to lock it, lights, stereo, chopper style handlebars, tan seat and grips, whitewall tires and some paint to make the box black). Total weight of the bike with motor and batteries will be approximately 250lbs (130 for the bike, 80 for batteries and 40 for the motor, controller etc.). Weight carrying driver and maximum load is about 650lbs, typical weight in day to day use will be about 450-500lbs., driver inluded. I know this is a lot (!!!) of weight, so I hope I'll get away with no pedaling with a single motor setup on the rear wheel. The last couple of days I've been studying the technical aspects of ebikes to find something within my budget and so far I've come up with the following setup:
6x 12v AGM Deep Cell batteries configured as 72v (20ah, 40A continuous, peak current 90A)
Crystalyte HT3525 Rear hub motor
72v40a sensorless controller (Crystalyte or LYEN if he has a working one on offer)
The rear of the bike will need some adjustments as the dropout width is only 115mm and the bike comes with hub gears and a drum brake. Luckily it's a steel frame so hopefully I'll be able to bend it out 10mm on each side. For the gears I'm not sure yet if I'll install a single speed cog or a 7 speed freewheel, as pedaling will be very heavy wether there's gears on the bike or not. If I fit he 7-speed I'll also have to fit a new shifter, derailer, and a special eye for it on the axle as the bike frame doean't have a mount point for it. I've found an adapter to fit a disc brake caliper on the horizontal dropouts, originally intended for those cruiser/chopper bikes, I hope I can use it together with the torque arms. I want to remove the rack on the back to give it a bit of a cruiser look, so the batteries will have to go either in or under the box.
Is this ever going to work with a decent range or this thing just too heavy for a single motor setup??? Can anyone tell me how well the sensorless LYEN controller works on the new crystalyte hubs as I hear mixed reoprts, I need it to be able to take off from standstill (the sensorless crystalyte can do this I believe), I have no problem with shudders at 32mph as I can't imagine going any faster than 20-25mph with this bike. Is 72 volts the way to go here or should I upgrade some wires, try to find a higher amp controller (or beef one up) and run a lower voltage, I don't care about top speed, even 15mph would be fine, I just need loads of thrust.
