waynebergman
I think you have done a good job in removing any rubbing noises and the high pitched sound is maybe something you can muffle somehow after the motor is firmly mounted in the bike. I know in aluminum boats people like to put either carpet or rubber inside the hull to soften the noise. I wonder if you glued say some 1/8" thickness of rubber to the outside part of the bike you have had custom fabricated for battery enclosure and motor mount. I realize this custom fabrication for your bike will act as somewhat of a heat sink for the motor as well for you but I am sure even a little distance away from where most of the heat gets transferred to you could experiment with some rubber glued or riveted to the aluminum structure. This may be a dumb idea but just trying to think of a way to silence this for you as I know you are concerned with the noise. Looking forward to your progress, keep the good work Izeman!
