sephiro499 WROTE-QUOTE<<<< Yeah after reading more it doesn't look too bad. I know for the hub motor it will either take the threaded flywheel or the cassette type. The reason I ask about the gears is because there are times when I may not want the electric power. I assume the battery will be the heaviest part of the kit, so if I'm just going outside for exercise I would disconnect the battery and lose the extra weight. Now changing to a 6 sprocket from an 8 sprocket I assume I will also need a new derauler and shifters, since on amazon it lists the deraulier with the number of supported gears. If I'm going to do this conversion I would like to do everything right the first time. This will also give me a great education and confidence that I can handle any replacement or maintenance in the future.>>>>END OF QUOTE
This, as with so many first timers, has gotten way more complicated than it needs be and I guess we are partly to blame for throwing lot's of irrelevent suggestions out there.
You stated that you are going to need to ride on the sidewalk and want to pedal, ok, that means low-powered geared mini-motor, PERIOD.
That Hill-Topper kit has that, and the couple of guys here on ES said it was an OK kit, but you would want to get one of the lithium battery options.
It mounts on the front with a few hand tools, the bicycle drive-line stays intact and it will be fine for what you want to do.
It's kind of slow at 15 mph, but a reviewer here said he could pedal up to 19 mph, so if your bike has the gearing and you have the leg strength, you could do the same.
It comes with a really low power controller, probably around 10 to 12 amps, so if you wanted to add things like a more powerful controller, a real throttle, torque arms, etc. later, you could do so.
Or you could save yourself some time and just get an Ananda Q100 kit like I susgested earlier, which comes with a real throttle, has better battery options and will be more powerful. The "Cute" kit is well thought of, not just by me, but by D8veh. And if there is anybody you should listen to, it's him. He is the low-power God/Guru when it comes to assist conversions, having built/helped build more than a dozen beautiful examples. If you want to do some research, search out his builds here and at Pedalecs UK.
Look at the three sites I susggested and go though the checkout to see what shipping will be, if you are smart about it, you will end up with a nicer conversion for less money than the Hill Topper kit.
Although I would just use a frt. kit, the Q100 is the easiest rear mount hub motor to mount available. There is room for you to use an 8-speed free wheel. Even though you wouldn't have to change out any of the shifting stuff, if you use a DNP free wheel, it probably won't shift as smoothly as it does now. Since you won't be going faster than 20 mph, I think you could have the option of using one of the nicer Shimano free wheels.
A lot of posters here who haven't yet experienced an Ebike think this, but the reality is, once you are electrified, you will use it all the time. You still pedal as hard as you want, you just do it now to go further and faster.
If I were you, I wouldn't send any more time to keep mulling this over and second guessing things, just focus on which mini-motor kit you want to go with and get it ordered.
Here are a couple of nice Q100 conversions by Grinz145 and zukster;
http://endless-sphere.com/forums/viewtopic.php?f=3&t=32364&hilit=zukster
zukster's is more what you have in mind. Note that he uses a 9-speed free wheel w/ a Q100 Rear motor.
