adsc
⚡ Regular
Shhhh
Transatlantic Shipping might be a bit expensive, not sure.I have a free 1965 Suzuki S32-2
I could get a Suzuki GN 125 here, it would be the same bike that you have, I think.I have a motorcycle with similar characteristics
Mine is EN 125I could get a Suzuki GN 125 here, it would be the same bike that you have, I think.
Make sure you understand the regulations before you make any important decisions.The problem with overbuilding is the 11kW limit for A1 category. I think the 6000W is rated for 12kW, so I'm not sure if it would be legal to use even that one, no matter whether the rest of the drive train can even provide that much power to it. I would have to ask the authorities.
And yeah, the 100km/h for 20 - 30 mins wouldn't be a regular thing. It's just, when you want to ride the highway, and there are lots of cargo trucks around, it's annoying and even a bit dangerous if you are slower than them, because they tend to not slow down and instead want to overtake you. And there are almost always lots of cargo trucks in the right lane on our mostly 2 lane highways in Switzerland. But I think the speed limit for them is 80 km/h (although it seems to me most of them are actually faster), so 90 km/h would probably be enough.
But I could probably drop the A1 category requirement. I thought it might be easier to make it street legal again, if it stays in the same category, and also of course more people could ride it (a lot of people still have A1 from their regular car driving license).
Lots of parameters to think about.
Yeah, sure I will. I have also spoken with some other people about it, and one has remarked concern considering water and how to get the battery pack watertight. I personally don't think it will be a big problem, but I frankly am inexperienced when it comes to waterproofing things.Make sure you understand the regulations before you make any important decisions.
Yeah, I would probably go with a spoke motor, I think it looks best on this type of bike. I don't really care about looks THAT much, though, so we'll see.Siaecosys has a 8kw 17inch spoke motor
Yeah, I have already planned to put either the controller, or an onboard charger under the tank. It depends on the battery design, though, I will first try to design that and figure out how to mount it and then design the rest around it. Since I'm probably going with a hub motor, it should be possible to make it large enough without it becoming too tall, but I will probably have to fold the 24s in half at least, if I'm going with the 40mm round cells. 96V will be impossible with those cells, though, I'd have to go with different cells.You could install the controller under the tank.
look at the space you have under the tank
you cut it down
the widest battery, not tall
and in 96v
So are most of the companies that make "waterproof" devices, even when they claim IP ratings of various levels.I personally don't think it will be a big problem, but I frankly am inexperienced when it comes to waterproofing things.
