amberwolf said:For best reflective visibility, make sure you use *real* retroreflective tape, like the stuff by 3M (not the bajillion counterfeits), which reflects from many angles and does so very very well; it's what is commonly used on street signage and markings.
If you like, rather tahn depending on the cars having their headlights on and pointed at you (so the reflective tape works), you could *also* use actual lighting strips.(with the reflective stuff also there for when you don't have any power, etc).
See my SB Cruiser trike for a few options for those (I think I also posted a couple better versions with built in blinkers in a post above somewhere).
I used to use just reflective tape (I still do in places) but it wasn't sufficient for the numerous places and times where a car's lights or those in surroundings (if any) weren't sufficient for them to see me, and if I had just proceeded instead of assuming they didn't see me, bad things could have ensued.And other cyclists that aren't really paying much attention and/or have no light source of their own (very common here)--the lights they see a lot farther away and constantly, rather than just the moments when enough light hits at the right angle.
Yes, the 3M reflective tape is very good! The bike will also have front and rear lights.
Maybe led strips on the side, but would love to insert them in the frame somehow, with small round holes in the steel tubes... I mean I would love the look, not sure about the strength of the frame being affected...
