Freewheel Tool for Cromotor
Excellent News!!
The new Freewheel and Park FR-6 tool DID ARRIVE today, and I immediately set to work. Do you want the good news first? OK, the Park FR-6 FITS OVER THE CROMOTOR AXLE! I was concerned about all the freewheel tools that had to be drilled or ground out to fit over the axle, and the Cromotor's axle is thicker than most. One challenge down.
Now for the not-so-good news. It doesn't fit over the threaded tube the freewheel screws onto, and on my motor that sticks out as far as the freewheel. The tool's teeth have an inside diameter that is too small.
More good news, though. I chucked the Park FR-6 into the lathe and touched it with a file, and it didn't glance off. So I mounted a carbide cutter and turned out the teeth until they cleared the motor's freewheel mount. Sharp eyed viewers can see the cuts on the inside of the tool above. Easy on a lathe.
The rest is just labor, take a big wrench, remove the freewheel, grease the threads, put the new freewheel on, remount the wheel (no easy task on my Borg), redo the tiewraps, reinstall the chain, reinstall the tensioner. Whew. Remember to retighten the wheel nuts daily for the next few rides.
I wonder if, from now on, I should change the freewheel when I change the tire (3,000 miles or so). This Dicta freewheel lasted a bit over 4,000 miles. Or would oiling the freewheel really help? What to the bicycle experts say? Is there a better freewheel that will fit in this tight space?
