Computer Dan
- Joined
- Aug 16, 2019
- Messages
- 17
A friend gave a an old broken Cruzin Cooler 500W 50 series. Turned out the batteries and controller and throttle were toast. I replaced the old lead with 2 36V 7.8ah lithium battery packs run in parallel. I then bought a cheap 36V 500W controller and throttle with a key. Everything appeared to be working fine, this thing really hustles getting up to 25mph rather quickly. My back drive tire is getting bald from doing donuts and hitting bumps, loosing traction and then gaining it with a little burnout. Great fun although not the safest, just the way I like it.
Here is the problem. After thrashing it around for a while it just dies. I rode it 2 miles and all was well until it wasn't. No power what so ever. I had to turn off the switch, unplug the batteries from the controller and plug everything back in and it will work again for a while but eventually die. Still plenty of juice in the batteries and while the motor and controller are hot, I don't feel it to be excessive and the cause of my issue. I also replaced the stock thin wires with much thicker wires as the old connectors and wires melted in 5 minutes. Any ideas out there? Is my controller a cheap piece of garbage? The batteries are the exact same setup as my Ezip 700 and my Mongoose FS and work just fine with those. Thanks for anyone that can help.
