Well, this post
I bought a 3 wheeled Cushman Truckster to convert a few years back. The engine didn't run, but I was told it did. I got it running within a few hours of getting it home. It never idled right and though I though I knew why, I never really messed with it much. I knew all along I wanted to convert...
endless-sphere.com
states which parts were used.
Based on a quick google for phrases out of that, and matching up images in the results to those in this thread,
the motor is this
Electric Car Parts Company is your one-stop-shop for affordable electric vehicle parts and components including batteries. Shop our selection and order now!
www.electriccarpartscompany.com
but you'd have to make or have made an adapter plate and coupler to connect to your drivetrain.
The controller appears to be the 7245 on this page
but I dont' think they make those anymore; you'd be best to ask them which current product is the best match for whatever motor you end up choosing.
The batteries used may not still be available after this many years (and probably wouldn't still be all that good after so much aging), but there are lots of batteries out there depending on what you want to do / how much range you need. Given the ~200wh/mile that Drewjet reported for his usage at some speed below 40mph (his reported max speed, since the wh/mile usage doesn't have a speed or conditions associated with it, we can only guess), then for your higher speed desire you should guesstimate 300wh/mile just to be sure you will have enough capacity for the range you want.
What he used was 75v x 120Ah, which is 9000wh. At 200wh/mile that would give him a possible range of around 45 miles. (assuming that 75 he reports is "average" or "nominal" voltage--if that's his full voltage the Wh and range would be less).
You need higher speed, so you will either have to use proportionally higher voltage, or different gearing between motor and wheels to do that. It will also take more power to go the higher speed (quite a bit more than you'd expect given the apparently small difference), so you'll probably need a bigger controller and battery, too.
So if you wanted, say, a 10 mile range, you would need at least a 300wh/mile x 10 mile = 3000wh pack. For a 72v system that would be 3000Wh / 72v = 42Ah. If you need more range you'd need a proportionally higher capacity pack.
Which specific battery to use would depend on your budget and your DIY skills. It's unlikely to be cheaper to build your own pack from separate new cells, but it probably is far cheaper to buy used large-EV modules from places like BatteryHookup, etc., and use a separately-purchased BMS (like the contactor based units from JBD), as the one that comes on them (if any) probably isn't usable outside the original EV they were for. (used EV cells is what Drewjet used)
Whether his solution will work for your needs depends on what they are. For instance, if you have to add much extra weight to your Cushman, such that it has something like this one does built in
I have a three wheeled chinese electric foodtruck - like a Piaggio Ape. I was excited to upgrade range by adding a 60v 150AH Lithium battery pack from 60V lead acid. Custom made by Smart Propel but based on this 100Ah version. Charged the pack and installed it. It charged up to 73v. Managed to...
endless-sphere.com
then you may need a bigger motor, controller, and battery to do this. If you're just driving around with some small coffee deliveries, it's highly likely that his solution would work, if you only need the same speed / etc he had.
