torqueboards
I'm looking to gain experience in electronics so as a project (always the best way to learn anything). I'm going to try and make a custom 2.4ghz transmitter/receiver with all my ridiculous features. This is a probably long project and no definite date on completion but it's something I wouldn't mind working on from time to time. For all I know it might not ever be completed, hopefully not!
The objective of this post is to share details, ideas and develop the best custom 2.4ghz remote controller for an electric skateboard.
I'll be getting a bit of help on the project so I won't be going in blind. Should speed things up as I won't be starting from scratch and not as much trial and error.
In the beginning it will be a 3D printed enclosure.
RC Transmitter Features
- Works as a Standard RC 2.4 Ghz Transmitter/Receiver
- 2.4 Ghz Transmitter/Receiver
- Small form factor / small handheld controller
- Reliable Transmitter/Receiver - No Disconnects. Option for extending signal/antenna.
- No dropping or interference
- Programmed in Arduino
- Uses small lipo battery as main power source.
- On/Off Power Switch with Green/Red LED
- Mini USB Port for charging handheld transmitter
- Cruise Control button - automatically will gradually start to 3mph and throttle up/down will accelerate and decelerate. Cruise control resume within 5 seconds, gradually resume to cruise control last speed.
- Speed button - slow, normal, sport - slow is under 13mph and low throttle. normal is normal with decent throttle up to 20mph+. sport is acceleration as fast as you can throttle.
- Remote Handheld Battery Indicator - Green for charge and turns orange then red and brightness changes for charge level.
- LED lights/screen for battery pack voltage and/or bars or % for battery pack life.
- Signal light LED for transmitter and receiver sync or connection. Wifi type icon.
- Dead man trigger
- Throttle control - Decide between Boosted, Evolve, Yuneec (Wheel, Trigger, Slide)
- Option for flashlight on controller
RC Receiver Features
- Option for up to 4 ESCs using 3PIN connector. Automatically disregard positive/power line if more than one.
- Option to power through UBEC/BEC with 3PIN connector.
- Plugs into battery source?
- Ability to plug in 4 or 5 LED lights.
Ideas
What features do you think I'm missing? What kind of controller
- Dead man trigger
Ideas
