I balanced my battery and now I noticed that at 45V the bike drops voltage sharply. It goes a maximum of 18-20km/h. Although when it was 46v I was easily going 40km/h. Should it be like that?If the display turns off then it's usually because the battery itself turned off.
If the display stays on but the motor stops working it's usually because the controller reached LVC or some other limit.
If it's a battery issue, it's usually because of a cell problem, either mismatched (poorly built or qc'd pack) or failing (old, damaged, etc pack).
when it was 46v and more. the engine gave out another 750w (possibly more), but when it was 45v it was about 150wI balanced my battery and now I noticed that at 45V the bike drops voltage sharply. It goes a maximum of 18-20km/h. Although when it was 46v I was easily going 40km/h. Should it be like that?
everything i have saw looking up things to hook my s866 display to my random controller to see if it reads speed because my bafang c965 display wont anymore says that PL is power lock if you have a key etcso Pl is the voltage line.....
the p+ is the 5v line to power the screen.
Controller is flashable and programmable and it powers up but the voltage will jump up to 60'ish volts when i engage the throttle and release.
i am hoping someone was able to flash a stock firmware that will overwrite the second MCU that has the error.
Speed sensor seems to be borked also
i have an old controller i might try on it see if the problem persists
if anyone has a link to a stock BBS02B firmware i would be forever grateful!!!!
EDIT:
The config tool will show an error in the log when the two temp sensors are active and engage the thermal limiter.
It will also show unable to get Voltage from controller.
The error 30 is gone (i had Rx and Tx swapped in my infinite wisdom)
Definately will not work. Out of bafangs this is only for mid-drives(and of those only bbshd+bbs02).im tempted to try to use this program and read/write to it too but i dont want to mess it up, i guess if the other program didnt mess it up this one probably wont either i have backups anyways but im kinda hesistant on trying it lmao
any ideas on if it will work or not or if i should try it? i dont think i will get much out more out of it other than maybe getting speed to work again, i couldnt set current limit above 18a anyways either (it says max 15a on the controller) but it sure seems like it has a lot more power than 350 watts with the 350w controller and 2x 250-350w geared hub motors
You could open a issue on github asking for this? So that this might get documented doing it there.Could I do the same and downvolt a 52V TSDZ2 to 36V without any issues?
iirc., the controllers have caps w/60V ratings, so you don't want to do that.With this firmware does that means that I can use a 15s battery if I set the voltage limit to 63V (Maximum rated)? Is it safe to do it like that and use 33a? I have a nice idea for a 15s battery.
Nice! I am thinking about limiting my cells to 4.15v and getting max 62.25v. Do you think this should be safe enough?iirc., the controllers have caps w/60V ratings, so you don't want to do that.
edit: nvm., came across my old controller, and those caps were indeed 63V, fwiw..
I'm experiencing the same issue. i have two 52v battery packs. significant power loss at 45v. I'm thinking maybe voltage sag? were you able to fix your issue?when it was 46v and more. the engine gave out another 750w (possibly more), but when it was 45v it was about 150w
52v battery is 14s (not 13). 42v should be zero percent for a 52v packAm I missing something or not? For 13S battery, 45V means your battery is near depleted, so the firmware cuts the power (because its near the cutoff voltage configured in the Config Tool). If you went full power in 45v (by configuring cutoff too low), it would sag to "dangerous" levels.
I have a BBSHD, using a throttle for BAFANG.Give/show us the configuration? Atleast for these three variables, that affect it the most:
Start Voltage, End Voltage, Start Current
Configuration Tool
Open source firmware for multiple electric bike motor controllers. - danielnilsson9/bbs-fwgithub.com
Without configuration(+setup ie. bbs02 or bbshd? bafang throttle, or not?) it is plenty
harder than necessary to help.
I don't know anything about eggrider, and atleast the throttle settings don't look compatible,I have a BBSHD, using a throttle for BAFANG.
Here’s the settings I tried to match, they’re from the EggRider before I flashed the custom firmware but I matched all the values and sent the changes but it didn’t change the throttle. I was wondering if I needed to flash the custom firmware again.
try different usb ports and restart PC (that worked for me at least)Has anyone had any connection issues for the BBS-FW tool? I can't seem to connect. Cable works fine with the Luna programming software but when I try this one, it just hangs on the green progress bar and give me a "Failed to connect, timeout occurred" error
