Hi Guys. I'm quite new at this stuff. I've read a lot and learned alot.
My current bike has a custom shaped 48 volt samsung 18650 battery pack with 192 individual cells that I made myself.
This is the third and largest pack I've made for my bike. It's big so I have lots of range on a single charge.
But now MY PROBLEM IS CHARGING.
I've been useing 2 imax b6 24 volt chargers and charge my 1 48v pack in 2 separate 24v packs.
Buutttttt, for whatever reason, the imax b6 will not put out more than 2.1 amps during charging. (any idea why?)
Now that my pack has a lot of capacity, it takes about 12 hours to charge from empty till full, which i would like to quicken up a bit if possible?????
I'm looking for a 48volt charger or bms that is simple to adapt to charge my battery.
I'm also looking for the cheapest option without it being junk.
Something like this maybe http://www.amazon.com/dp/B00VB2BXGG
but under $100???
Thank you in advance for your help!! =]
but under $100???
