couldn't find a decent rear LED bike light, so figured I'd make my own, and then cast it in resin to waterproof it
bought a few bits to build a small test one, was only planing to test with a few LEDs but them my HD crashed so I had some time last night while I was re-installing
rough plan was, yellow each side for indicators, solid on red for brake lights, and flashing red for normal bike light
bit bodged, just used the stuff I had lying around on my computer desk while I was reinstalling windows/software etc..
all went pretty well, I mostly just bent over the legs of the LEDs to join to the next one, knew I'd run a thin wire down instead for the proper one I'll use, so I did the last couple of lines of leds like that just to test (much tidier)
no idea what resistors I should be using for these, I've used 4 x 120ohm in parallel for now, they're just what I had to hand, not sure what wattage they are, running from 12v right now, they're ok as long as I only power up 1 set up at a time, if I light yellow and red together they all go dim :-o
PHOTOS:
2 lines of yellow LEDs, 2 lines of red LEDs, mixup of flashing RED leds, then 2 lines red and 2 lines yellow again
rear view
clean resin (from ebay)
mixed the first pour, 100ml resin, 1ml hardener, poured into old ice cream tub
wait for it to set, but still be tacky/sticky (like gel), mix and pour another 200ml in, the put the LEDs in face down, pour another 100ml in ontop
I know resin gets hot when it sets... but this got crazy hot, it melted the bottom of the ice cream tub, so I took it out as soon as I could
closer inspection... and most of the LEDs have melted (the crask in the resin was me taking it out too soon)
but... they (mostly) all still work ok
vid of flashing LEDs
http://imageshack.us/clip/my-videos/534/4hsfwkjiispeinfnnsokpw.mp4/
sorry some of the pictures are a bit crappy, it's pretty hard to photograph the LEDs in the resin
things to do differently next time...
I used some 5mm and some 3mm LEDs for the flashing ones, the 3mm ones were pretty naff, and then burnt out (probably needed a bigger resistor for those)
ordered some of the right resistors, and I'll put one on each leg of LEDs to keep them cool
the flashing LEDs are a bit naff, because they don;t flash in time with each other, from a distance it's not a bright light, more of a twinkling light - so I'll just use all normal leds, and then use a flasher relay to flash them
the resin is incredibly clear, like glass, but because the LEDs melted the light is more diffuse now, not as focused, no next time I'll cast it the other way up, I'll put the LEDs in face-up and I won;t cover them, Ill put in just enough to waterproof them (I think if I do small amounts I could keep filling it up a layer at a time to cover them if I need to)
might also spray the protoboard with silver paint, so it's a bit more reflective
that's it for now, I really need to wait for it to get dark so I can test it outside and see what it's like in the dark and at distance
these are 8000mcd LEDs... about the brightest I could find without looking too hard, might try to get some brighter ones for the final version
PHOTOS:
rear view
