Kepler said:
Have you run Q100 on 18S? Does the over volting really matter if you keep the amps under control with a CA?
I tested the Q100 at 15S with the BMSbattery.com KU63 controller, but just around the block. Nothing blew up or melted, but I suspect the KU63 has a 63V capacitor in it so 15S*4.2V = 63V is pushing your luck. So I am more comfortable at 14S for my bike with the KU63. The controller says 15 amp max.
I ran my Bafang at 18S (75V) a few times with ebike.ca's 20 amp controller. The nylon gears stripped though, so I switched them to metal. I find its prone to overheating on hills or under load for 14S and up if you don't keep an eye on it - it can get too hot. I burnt out an early SWXH this way so I know. It seems pretty tough with the metal gears as long as you don't overheat it.
Maybe you could use the CA to monitor amps and help with this somehow? With the Bafang anyway. I really don't know how much abuse the Q100 can take. I have not used it for pulling a trailer. I thought it was too small. It does have two sets of planetary gears stacked to achieve its small size however, so this would spread out the load over more gears, so perhaps they would hold up okay under more of a load.
If I was going to try this I might try 16S limited to 15A to start with, and see how it holds up. I'd try it one of Lyen's programmable controllers but I'm currently working with him to get the controller working better with the Cute 100. Once that is sorted out, I can program the controller to a max of 15A and give it a try. If I get that far before you, I'll let you know.
I just ordered a new crank that has 48/36/26. I'll be looking forward to trying the 328RPM Q100C and a cassette with an 11T cog. The bike will then be able to be peddled at the higher road speed the 328RPM wind will take the bike up too. I like to be able to peddle the same speed the motor can take the bike up to on the flats.
