d8veh said:
cycleops612 said:
yes i know, weight is of the essence, but a 24v 5 or 10 amp (1 or 2kgs of cells respectively) lifepo4 battery would tempt me.
LiFePO4 has more or less had its day for electric bicycles. It's simply too heavy. Why would you want to use it?
i know thats the conventional wisdom, but am not so sure
an 18650 (LINm assumed here) is 50 gm, 10 amps life po4 is 250gm. 4.2v (yeah right, for the first 5% of discharge) vs 3.3v ~constant
mainstream: 18650 =2000na - same weight bar claimed voltage
20% of 18650 is pure dead weight - unusable
1 c discharge on 18650 (for 5 minutes & then dropping fast to uselessness for ebikes in many roles) vs 2c constant and i strongly suspect 3c doesnt hurt much.
2 things recently
1/ killed a $350 retail replacement bottle 18650 10ah 36v (rated but total BS) simply cos i for got to fuss over charge level while unused
2/ i left lights on on a new $200 retail lead acid car battery. i am told i have halved its life and next flat, may as well toss it
Further, what are the odds many of us have time or talent to diagnose
15 amps of 2000ma 36v i make is 8.5x7.5=64~ cells, arranged in parallel, poorly bmsED groups. any failed cell affects the whole, and must be located and solder replaced - 4 connectors.
its not gonna happen for most.
12 x 15 amp pouches in series tho, is diagnoseable and fixable, even for me.
THIS IS A VERY REAL RISK, AND THEREFORE COST, TO FACTOR IN
LIFEPO4 IS RELATIVELY BULLETPROOF it seems, literally - still sorta works after being shot, even with a garlic coated bullet.
2000 charges means it never wears out (or even 1500 is forever if you aggressively fast charge it), vs a few years for 18650 if you have a perfect run and endure reduced storage and performance
on paper, 18650 yes, real world, i am far from convinced. 2000 charges is a full cycle every day for ~6 years
on balance, i would perhaps take a 10 amp lifepo4 over a 15 amp 18650 rig. lets see how weights compare then?
I love that there is no need for messy parallel cells, just choose the pouch size you want and wire in series to get volts you want. baba bim...
very simple and consistent quality pouches and simple construction where each individual cell has its own bms channell.
lifepo4 would be a far more robust battery for heavy users like forklifts, taxis, pedi-ecabs, delivery trucks...
charge speed can be a killer factor for power users, and not just full charges over night. Its interim top ups too. How fast can i pump it up to 80% during breaks & therefore work it all the shift.
we can all only speak from our frame of reference, and i am 75kg and from a sort of centralish burb in EU rules Sydney with trains and mild hills. 7km is a big trip for me but i use it almost exclusively over my car.
Americans e.g seem very much larger mostly, 700watts~ is ok and more spread out (car centric), so i respect their different needs.
battery weight has to be viewed in the context of GVM. for me its 100kg~ ex battery. for a 150kg rider, it would be 175kg (more really due to needing a heavier bike). There is a big difference in the relative effect of an extra few kg of battery. Best to focus on whats the best battery, then consider weight as a percentage increment of the total.
briefly, as may be repetition, my 12ah kosher panasonic bottle battery is 12x36v=432 watts right? BS. It only shows 4 bars on my meter after mere minutes of full use of my 350watt motor. Then its a wimp and no fun.
