nearly 1k mile wear update, fairly heavy stress testing. Gears are perfectly fine (looks misshapen but it’s just grease), but the grease went bad likely much earlier at around 600 miles, when i started experiencing issues like higher noise levels, and sudden drive loss and scratchy noise (to be fair a little debris in the shaft and chainring area likely contributed to drag).
View attachment 384388I would honestly recommend checking factory grease before 500 miles. Grease looks like gruel and will be replaced with new molykote br-2 plus
View attachment 384389View attachment 384390
PS: removing the chain guard is tough after not removing it a while, even though i removed it fairly recently to regrease. the chainring adapter is the toughest thing I’ve ever had to remove. Doesn’t really matter what tool you have because the wheel rotates all the same when trying to remove it, need really strong determination, and possibly a heat gun and mallet and vice grip
