cycle analyst 3 wpx with mf switch brake stopped being recognised
entewerks
Essex
hi guys,
have a bit of a problem wondered if anyone else has had this, my braking is no longer being recognised by the ca, it worked for about 4 weeks on my new build and then stopped yesterday. I'm using 2 pins on 1 & 4 . I've traced and checked all wires, getting 5v through when I pull either brake lever but ca is no longer registering it, I've unscrewed the ca and I have 4.90v feeding back to the board with brakes on, has anyone else experienced this? or do i have a dodgy board? I have flashed the firmware to rese (3.15) and left only the brakes connected but still not recognising the input
What is your brake switch setup? Pulling the lever would normally bring the signal wire to ground, not 5v.
hi, thanks for reply, fixed, it was a broken pin in a higo giving intermittent signals, didn't think of checking that initially, depended on how the wire was laying. thanks anyway. if you're interested, my brake set up is high as i run a thumb throttle for independant regen.
