hey guys , im a bit frustrated .
the thing is i just added CA 3.0 directly in the controller (1500 ) , most of the things seems to work fine beside throttle\speed issues .
when connecting the thumb throttle directly to the analyst , it spins normal with no load , but when im on the bike , it gives short bursts of movement -> then stops and the small throttle indicator on the left starts flashing .
when going to trottle input settings , the V value always changing as it should according to the twist , but the percentage stopped responding .
after 3-4 hours of tries i decided to go home and deal with it later , so ive mounted another throttle directly to the controller, thinking i may bypass the CA .
begging of the ride seemed like the usual , before the CA , but , somehow i only could ride 30-35 kmh ( i get 80 without CA ) .
went through the menu thousand of times making sure theres no speed limit\power limit or anything else but no luck .
any ideas ? had a hard time finding any kind of troubleshooters online also .
