chuyskywalker
I'm trying to make sure I've got the right understanding before I drop some cash.
I'm building up a 72v based bike and would like to add a PAS sensor. Right now, I'm happy to try out the "lower end" cadence sensor from Grin. Maybe in the future I'll consider a torque spindle, but I don't think I need that for now.
Reading up on things, however, the manual states:
From what I've gathered in other threads, I understand that the dc/dc into the CA just gets overworked pulling 72 (really, 84v) down to 10v and can cause it to fail. Pulling up the un/official guide shows that at 84, there's only 10ma and a PAS alone could potentially pull that -- no bueno.
In this other post, it's alluded that if you have a 12v system in place (I've got a 90v->12v dc/dc that can handle 26A for accessories), you can instead just power it directly, instead of from the CA.
So; should I buy the PAS above, I would need to remove the +10v pin from the connector and wire it into my 12v dc instead, right?
The device doesn't claim to accept 12v (instead 5-10v), so would I need to add another step down?
PAS and torque sensors are only compatible with battery voltages lower than 52V nominal when the Cycle Analyst is providing power for the device. Connecting a PAS or torque sensor to the CA3 above 52V nominal voltage may cause damage.
