Cycle Analyst Throttle settings
katzda
I'm I the only one thinking that the throttle settings is a bit limited?
My throttle-in voltage is set for range 0.82 - 4.21 but the way it changes is non-linear. The lower end changes much slower then the middle to high end of the range. This means I when I gradually push it, I get output power like 70W, 140W, 750W, 900W, 1000W, 1100W, 1200W.
I wish I could customize the mapping to the output voltage using some curve function that would be customizable using several variables. We could use an external program like this one to design the exact curve needed,
