Date codes on bike tires?
tomjasz
1 GW
Out riding, MN USA
Are bike tires date coded? Nokian?
If it uses standard codes then this would apply. However, I doubt many bicycle tires used dot codes. Some do though.
http://en.wikipedia.org/wiki/Tire#Markings
No date code on any of the Nokian tires that I have here. Most of bicycle tires don't last very long anyway, and they are thin enough to show obvious signs of aging on shelves.
Nevertheless, I ride one "new old stock" 10yr old 3.0 Gazzaloddi on the front right now and it is still a very good tire. Rubber ages fine on the shelves if it is not exposed to sun light.
Thanks, I've tried contacting Suomi Tyres. I've found a couple of really attractive prices on used tires but would like some sort of measure to use. I can't imagine they aren't coded somehow.
you just fold the sole and look for cracks on the surface of the rubber between the knobs.
There's a circle a like a clock face with a year, an arrow pointing to month, code on Suomi tires.
Kiriakos GR said:
This is an interesting topic.
Does any one has experience with Schwalbe Marathon PLUS? Do they come with production date?
Their production code is inside the tire. It is 4 digit I believe mo/yr.
From Schwalbe warranty pages,
"Required: The production code is stamped in white ink on the inside of the tire comprised of 5 numbers, one letter then 2 numbers. (Sample: 23107X12) This is NOT the barcode number."
Kiriakos GR said:
Thanks.
Do I win a visit to Greece! I envy you riding there! What do you ride and would you share where?
μετά τιμής,
Tom
An answer from Nokian/Suomi tyres. Nicely translated!
