Hi, I am having some serious trouble with my Zero FXE 2022. It's just out side of warrenty and I'm New Zealand with no service support. Any fault find support would be hugely appreciated!!
The bike was running well until a week ago and now it is almost completely unresponsive.Turning the ignition on just gives a double flash of the red LED charge symbol on the display. I have no 12v accessories and no indication of charging other than a change in LED state on the battery pack.
The bike only has around 3000 miles on it. Battery LED indicators are showing a healthy state and half charge state.
Thanks in advanmce for any tips/info! i would love to get this thing running again
- I have checked high and low voltage fuses
- I have reset the BMS hardware and software via the buttons on the pack
- I measure 11.5V across the ignition switch (is this a healthly volatge?)
- I measure a pulsing signal on the enable wire to the DC-DC converter when i turn on the ignition
