Toshi
Ok, I'll check the voltage on each cell before shipping it.
So none are 0V but it's not particularly well balanced. Hot off the charger with a total pack voltage of 56V some cells read as low as 3.51V while others read 3.8+V. Then again, I was reading them off the terminals while they're all wired together so there's probably some inaccuracy produced there.Toshi said:Ok, I'll check the voltage on each cell before shipping it.
I jetted to the library today. 5.6 miles round trip, 18-22 mph cruising speed while pedaling at "12 mph" non-e-bike effort, gear 6 of 7 on my Nexus hub... and that yielded 19.8 Wh/mi.veloman said:If you drop your speed to around 20mph when possible, it will really help your range. I get around 20wh/mile with lots of 25-30mph stretches, but also a lot of slow city coasting and 23mph cruising.
Just slightly less ridiculous: Giro Advantage 2. $123 at REI, which may not be the cheapest but has a great return policy and a local store...Toshi said:One thing I still want to address is wind noise around my ears. Even with my normally-for-motorcycle-use -35 dB Westone molded earplugs in place there's still a lot of it, no doubt due to the aerodynamics of my head as it goes away with my head turned.
Something Iike this would work but would be ridiculous:
Those were my round trip stats, not for a single direction. Gear 6/7, pedaling along constantly, 21-23 mph.veloman said:You don't want to be draining your battery 100% every day. Plus there will be windy days where you need more power. I still think you can get below 20wh/mile if you don't have to go above 25mph too much. Maybe grab onto a passing truck and put your regen on for a few miles....
Toshi said:Just slightly less ridiculous: Giro Advantage 2. $123 at REI, which may not be the cheapest but has a great return policy and a local store...
http://www.rei.com/product/809816/giro-advantage-2-bike-helmet
My god, I'm a nerd...
