scfoster
New to this forum and looking for advice on an ebike conversion or purchase.
I have a 2008 Cannondale Rush 3 Carbon frame bike laying around (yes I should have sold it for the case a long time ago) the specs for the bike are here.
Cannondale Rush 3
Model Code: 8Vm3
Frame: rush CarBon, 110 mm
Fork: LeFty speed Bonded dLr2, 110 mm
Rear Shock: FoX FLoat rp23
Rims: maViC Xm819 ust disC, 24 hoLe
Hubs: CannondaLe LeFty Front, sun ringLe dirty FLea rear
Spokes: dt swiss Competition
Tires: maXXis CrossmarK XC ust, 26 X 2.1”
Pedals: CranKBrothers egg Beater
Crank: Fsa aFterBurner megaeXo, 22/32/44
Chain: shimano 9-speed
Rear Cogs: sram pg-970, 11-34 Bottom Bracket: Fsa megaeXo Front Derailleur: shimano LX Rear
Derailleur: sram X-9
Shifters: sram X-7 trigger
Handlebar: Fsa XC-281aos, 25 mm rise
Stem: CannondaLe XC3 si, 31.8 mm
Headset: CannondaLe headshoK si
Brakes: aVid juiCy 7, 160/160 mm
Brake Levers: aVid juiCy 7
Saddle: Fi’Zi:K nisene sport mg
Seatpost: CannondaLe C3 2014 aLLoy
Sizes: s, m, L, X
Colors (codes): Vredestein team (gLoss) (rep).
uni CarBon w/patriot BLue gLoss) (BLu).
Extras: CannondaLe V-teCh grip
I'm 6' 3" tall (190.5 cm), 195 lbs (88.5 kg) with a daily commute of 5.1 miles each way (8.2 km) with a vertical climb/descent of only 300ft (91m) with only one relatively steep section. The road is 50-50 urban street (with break down lane) and city (lot's of stoplights, parked cars and sidewalks). I want to assume I will NOT have the ability to recharge the batteries when at the office, so a range of 10 miles (say 20km) will be necessary. I would prefer to keep up with traffic in the City and would love to be able to do 40 mph if necessary.
I currently use a BMW 800GS motorcycle and it takes around 20-30 minutes to get to work. Found a place to park for free (thank you Amtrak) so gas and parking aren't much of a consideration as the bike get 50mpg. Looking more for the convenience of parking right outside the office door (bike stand right outside) and the occasional LIGHT mountain biking trail use. Not deluding myself that I'll use this for commuting 95% of the time, if I use this bike.
Regarding technical skills, I know how to use a soldering iron, voltmeter, I'm an aeronautical engineer and I do all my own maintenance on the motorcycle. So assembling things shouldn't be an issue. Willing to try and break a few things along the way (stuff happens). If I destroy the bike, I'm okay with that. Already thinking about how to fashion a torque arm to work with the carbon/aluminum frame.
So I'm looking for advice on what would be the best path forward or whether this bike is even suitable for conversion? Or, should I head over to Walmart to buy a steel framed mountain bike as the base?
I know this isn't going to be cheap but I'm willing to cut costs by assembling things myself and doing some testing.
Thoughts?
Thanks in advance (Scott in Delaware, USA)
Cannondale Rush 3
Model Code: 8Vm3
Sizes: s, m, L, X
Thoughts?
