I was curious, Delrin sounds like interesting stuff...
http://cncplastics.com/acetals.htm
"...Continuous service up to 180 F (82 C)
· Available in sheet, plate, rod and tube
· Available in white and black (standard colors)
· Low moisture absorption
· Excellent in submerged or wet applications
Excellent strength and stiffness
· No centerline porosity in Acetal copolymer
· Wide product size range up to 8.0†Thick
Easily machined
· Glass fiber filled grades for improved strength and stiffness
Acetal (Brand name: Delrin) provides high strength and stiffness coupled with enhanced dimensional stability and ease of machining. As a semi-crystalline material, Acetal is also characterized by a low coefficient of friction and
good wear properties, especially in wet environments.
Because Acetal absorbs minimal amounts of moisture, its physical properties remain constant in a variety of environments. Low moisture absorption results in excellent dimensional stability for close-tolerance machined parts. In high moisture or submerged applications, Acetal bearings outperform nylon 4 to 1. Acetal is ideally suited for close tolerance mechanical parts and electrical insulators which require strength and stiffness. It also offers resistance to a wide range of chemicals including many solvents.
Advanced Industrial offers both homopolymer and copolymer grades of Acetal including enhanced bearing grade materials. Our standard Acetal that we stock is a porosity-free Acetal and offered as our standard general purpose grade. For improved frictional and bearing properties, PTFE (Teflon)-enhanced Delrin AF products are available..."
