drewjet
GAry has been looking into getting them made for a long time. I know it's not his fault as he is at the mercy of his machinist. I am just looking for one...anywhere.
A while back, I was playing with the idea of using CFC rod/tube for pulley spokes, in a tangential pattern..liveforphysics said:As long as you leave enough meat in the center of the aluminum sheet to keep from tearing out the hub mounting area, you can cut the rest of it to feature something like 8 1cm wide radial spoke pattern cut into it to connect to a thin outside rim that the 4 pieces of delrin are affixed upon.
Around 16"deecanio said:Miles that would be a 165t - does anyone know what size that would be?
deecanio said:stealth is losing over ease of install and simplicity![]()
deecanio said:aye it does indeed kim, complet with built in freewheel in the 60t, nice
yes Miles 48v pack
D
AussieJester said:p.s Deec i believe i have accomplished something your after on your bike today, totally independent manual pedalling capabilities![]()
Thud said:Drewjet,
I opened the taper bore to .5" dia. It took out 95% of the taper. total PITA.
I am certain #35 is available in high quality alloys.
How many want one right now? If I tool up, how many in the first run?
Kevin,K-ray said:I know 10 is kinda small... thoughts (Miles) on noise / engagement?
Hoping to run a 3220 directly with a 10 tooth to just 92 on a 24" wheel.
Question also for you metalurgic guru's I'm thinking you need to temper again
after machining? I was just planning on reheating and quenching in oil???
